Hi. I have a F250 99 7.3 that is slow as dirt.
I have chased this problem for a while now and I´m starting to run out of stuff to replace.
THE PROBLEM:
I´m building about 7psi of boost without a chip, with MASSIVE turbo lag.Throwing code P1248 (No boost detected)
With a hypermax switchable maxchip (330+) i got up to about 15psi. Still with some turbo lag. Throwing code P1247 (low boost pressure detected)
Second to no black smoke. No whitesmoke at startup. Running fine and firing on all 8 at all times.
THINGS I HAVE TRIED/CHANGED:
1. Have tried disconnecting red vacuum line and wired the wastegate shut. No difference at all.
2. Have had the turbo out of the truck checking both wastegate and ebpv. Nothing wrong, the turbo is i great condition. (No play, good turbine wheel)
3. Have resealed the HPOP and IPR valve.
4. Have changed MAP sensor. No difference. Also checked for leaks, all fine.
5. Have changed ICP sensor.
6. Have changed exhaust back pressure sensor and line.
7. Have changed IDM.
8. Buzz tested the injectors. All sounds nice and crisp.
9. Have compressiontested the engine all fine, no blowby.
10. Have pressuretested the whole charge air system up to 2.5 BAR (36PSI) all good.
11. Have cleaned the pickup in the tank and changed the fuelfilter.
12. Changed the original exhaust for a 4" straight pipe.
13. Hooked up a fuel pressure guage, under no circumstance will it drop below 4BAR (58psi) no matter
the load I put on it.
14. Checked the IPR%. Flat out about 40% (under a load) and about 8% @ idle. I think thats All ok?
15. ICP. Have yet to hook up a machanical guage to see a true pressure. The ICP pressure is fine when
i look at it in the laptop.
At idle It stays at 3300-3400KpA (475-500psi)
At Full throttle under load 17000 KpA (2460psi)
In all records ivé found these are ok values...?
Think I got most things Iv`e changed and tested chasing this problem...
The truck has 247k miles on it without tuning. Had no hitch registered in Sweden, so I´m positive he didn´t tow with it since 2006 (when the truck got imported) Have no idea if it was towing in the US before it came here.
This is a well maintained, clean truck.
I Build racecars in all my free time and think I know my way fairly well around engines/cars and trucks.
Do anyone have a good recomendation on what to do next?
THE PROBLEM:
