Okay guys, new to this site, first forum ever. I have a 2000 f250 7.3L auto trans.
“mods” done are
Full billet 4r100
Billet triple disc torque converter
Bellowed up pips
Ebpv delete
Deleted pedestal
Wicked wheel
Hydra tuner
Custom tunes.
The issue is it will idle fine, a surge every other minute or so nothing crazy. But when driving if you let off the gas coming to a red light stop sign sharp corner etc, the truck will “key off” and die.
Throw it in neutral and it fires right back up 100% of the time. Truck runs beautiful at WOT it’s just when you are cruising and let off, it dies.
So far I have changed the oil, oil filter fuel filter
New IDM
New motorcraft ICP
IPR
CPS
The only codes I have gotten were (don’t remember the exact code #) but one was for the low/out of range icp
one for bad #8 cylinder mixture or whatever.
I’ve unplugged the tuner and it still does the issue.
hooked up to snap on scanner icp pressure is reading normal
Ipr pressure reads normal
Everthing looks Perfect and it just keys off.
icp plug is new no oil.
removed pcm there were no bent pins and wire harness checked out.
Even with the icp unplugged the issue is still present only thing that changes is it idles a lot more rough.
it’s been to 4 shops now and the issue can not be traced. Going to hookup a manual oil and fuel pressure gauge this week to see real analog readings.
Any ideas will be greatly appreciated. Any questions comments or concerns I can answer. The more thorough I am with you all can better help you help me. Thanks in advance guys.
“mods” done are
Full billet 4r100
Bellowed up pips
Ebpv delete
Deleted pedestal
Wicked wheel
Hydra tuner
Custom tunes.
New IDM
New motorcraft ICP
IPR
CPS
