1 - 8 of 8 Posts
I've been thinking about the Edge Juice with Attitude and i was wondering if you could stack it with another programmer.
Not a Dodge forum.
Search "edge juice with attitude" on here and you will find out the average feeling about Edge and their tuning.
Not a Dodge forum.
in fact, you can even apply the quote in the bottom of your sig :laugh:
Stay away from Edge tuning, and "stacking" anything is just bad.
Supporting Vendor
Well, if the Juice was actually a programmer, you wouldn't be able to. However, since the power function of the Juice has always been simply an injection pressure fooling device, then by all means, it's "stack-able". You can use it with either a flash programmer or a chip. Will you see any power gains by using it in conjunction with either tuning device? Nope. It will make the accelerator pedal more responsive and add a bit of fuel in the lower RPM ranges but once the high pressure oil pump has reached it's limit, you won't see any gains above what the programmer or chip was capable of in the first place.
Again, the Juice is not a programmer so therefore it doesn't have any "tuning" on it. It's a variable resistor for all intents and purposes. The CS and CTS Juice/Attitude devices include a transmission tuning option to alleviate the effects the older Juice modules had, but the power gains still come from fooling the injection pressure input to the PCM because the Juice module is STILL a Juice. The display (Attitude monitor) does the transmission programming only.
The Juice doesn't contain any "tuning" for the engine. "Stacking" these devices on a 7.3L isn't really "bad" per se, but there is little reason to spend the money on two devices that will only run just as good as aftermarket programming would by itself (Evolution, Superchips Max line of programmers, Hypertech, or any level of tuning for stock injectors that any of the "custom tuners" does, etc.).
The
Good info to know and even more reason to NOT run Edge products.
Thanks!
The
I honestly have not ever seen it described this well. It's as if you have worked for edge/ wrote their tuning, or at least know the guy that did haha. Thanks bill or the one at php who checks this site.
Supporting Vendor
Thanks.
Nope, not Bill, but I do 7.3L tuning for him part-time. :thumb:
i just got a cs attitude from a buddy but dont know too much about tuning yet and im still getting into it. right now my truck is a DD and i tow during the summer. from what i have read on here, the edge cs attitude is not good? and doesnt really allow you to tune your truck?
my main question is did i just waste my money and time, and should i take it off the truck before i do any real damage?
1 - 8 of 8 Posts
