Update with Data 7.3 Died suddenly, no start
Have a problem with my 2000 7.3 that I am at a loss for.
Was running perfectly, no issues.
Started it up, backed down the driveway, and it started missing, rattling and cel came on.
No power, and it died. Started once right after that, ran really badly, cel flashing? Would not start after that.
Now if I let it crank and pump throttle, it will stumble a couple times after cranking for a while but no start.
Here is what I checked.
Batteries fully charged.
Wts light works as normal.
Oil level perfect.
Fuel comes out of bowl drain under pressure when Key cycled.
Light white smoke when cranking.
New cps
No blown fuses
Wont start when plugged in.
Only have a cheap scanner, gets p1316 code
Won't start with icp unplugged. (But connector does have oil in it)
Really can't afford AE right now, looking for other ways to diagnose.
Any idea what to check next?
Oil level perfect.
New cps
No blown fuses
