Ran a buzz test twice, first time 2 and 8 failed, 1272 1278 1293 1294 passed the 2nd time. On the CCT Cylinder 2 failed. Which injectors does this motor have?
Its probably going to have the AD injectors but not for absolute sure until you pull the valve cover. Being its a 450 it may have single shots but I doubt it.
Sometimes a buzz test on sticks will pass and fail intermittently according to the laptop, but when you did it, did you notice a significant difference in how loud each one buzzed? It may still slightly buzz enough to pass but will be quieter than the others. That means that it is about to fail or is failing mechanically.
Cylinder #2 you definitely have an issue with. Did it buzz at all? If not, it could have just came unplugged under the valve cover. If it did buzz, but really weak, then its definitely a bad injector.
Now, if it didn't buzz at all and its still plugged in to the harness then you will need to swap positions of the injector to see if it follows the injector or continues to be a problem in that cylinder. If the problem stays in that cylinder then its a wiring issue (typically the under valve cover harness). Obviously if it follows the injector it the injector or coil pack on the injector.
