Yes do it while its still fresh in your head it sbould make it easier .Sleave retaining compound or loctite , has to have it . Sorry bro
Yes do it while its still fresh in your head it sbould make it easier .Sleave retaining compound or loctite , has to have it . Sorry broHey all,
Just have a quick question...
Just yesterday I Replaced all my injector cups and o rings, I cleaned the bore, but I forgot put 620 loctite on the cups... I just saw a video this morning about using loctite, and looked on forums about using loctite and my stomach sank. Is it super crucial to have 620 loctite on the cups? I don't recall any loctite on the old cups when I pulled them. I'm replacing them because I have the motor out and want to reseal it. It would suck to have to buy new parts but if I should, then I will.
Thanks in advance.
BothSo is the main job of the Loctite just to keep the cup retained? Or does it help with sealing too?
when you say check the oil in hpo rectangular thing in front of fuel filter, ?motor oil, or fuel oil ? mike.Try to read the code that is stored in the PCM... that would help tremendously with diagnostic.
HPOP loosing prime probably has something to do with the check valve assembly that you fiddled with.
The HPOP reservoir should have oil no lower than 1" from the top of the inspection plug.
Also by opening up the HPO system, it can take a lot of cranking and then driving to purge the air from the HPO system. With air in the HPO system you can get all kinds of funny noises and running conditions.
I'd suggest removing the valve covers and while cranking look for oil coming from each injector spout... no oil means the injector(s) isn't firing.
PS.... holy hell... try to limit cranking for 5-10 seconds at a time, otherwise you'll be buying a new starter sooner than later. Also have the batteries on a charger to keep them topped off while cranking a bunch of times.
