I'm posting here because this gets more traffic then the electronics section.
So I'm finally getting around to wiring up my 50" curved light bar and decided to go with some OTRATTW switches. I got the Contura V switch, green lower light and red upper light with the lower being independent. Along with the switch I also purchased their 6 switch holder for their switches and a fuse box that has 6 separate channels along with a negative bus.
Switch: https://otrattw.net/CONTURA-V-LED-LIGHT-BAR-LOWER-LED-INDEPENDENT-V1D1JCHB-PZCLB-540.html
Switch holder: https://otrattw.net/Six-Position-V-Series-Switch-Holder.html
Fuse box: https://otrattw.net/Blue-Sea-ST-Blade-Fuse-Block-With-Cover-6.html
She 6 switch holder fits nearly perfect within the overhead storage on a 2007 F250 (this is the style of storage that has only a sunglasses case, and a large open hole that looks to be meant for a CB radio). I found some sheet metal laying around my house that I used as a back plate to put the switch holder on. as of now I have the back plate i made in the truck, but I do not have the hole cut out for the switch holder.
Before I go any farther I want to make sure I have the electrical stuff planned out properly, I created a little sketch that shows how I plan to wire everything. if anyone has any good electrical background could you please just look this over and let me know of any thing I'm doing wrong? (fyi the lightbar I have is 288w so 24 amp). my main concern is what gauge wire should I be using? I'm thinking about using 12g wire for everything connected to the lightbar and the relay. and then using 18g wire for everything connected to the switch.
