1 - 20 of 44 Posts
What u talkin bout willis
OK GUYS LET ME HEAR IT...
MY 6 SPEED TRANS THE OTHER DAY WHEN I SHIFTED FROM THIRD STRAIGHT DOWN TO FOURTH IT DIDNT WANNA GO IN SO I LET OUT ON CLUTCH AND PUSHED IT BACK IN AND IT WENT IN BUT THE STICK FELT AS THOUGH IT WENT TO FAR WELL WHEN I CAME OUT OF FOURTH INTO FIFTH OR FINAL DRIVE IT WOULDNT GO WELL I PUT THE TRANSMISSION IN NEUTRAL AND IT WAS STILL IN FOURTH GEAR WELL I WENT INTO FOURTH GEAR AND IT ACTED LIKE IT WAS IN NEUTRAL AND WHEN IN NUETRAL ITS IN FOURTH WELL I LIMPED IT HOME (PROLLY SMOKED THE CLUTCH DOING IT) BUT GOT IT HOME AND FORCED IT INTO THIRD AND NOW ITS BACK TO NORMAL BUT DOSENT LIKE TO GO INTO FIFTH GEAR KINDA TOUGH WELL I FIGURED ID TAKE THE TOP OFF THE TRANS TO SEE IF ANYTHING VISUAL AND I CANT SEE ANYTHING ANYBODY HAD THIS TROUBLE BEFORE IS THIS COMMON OR A EASY FIX OR DO I NEED TO BITE THE BULLET AND FIND ANOTHER TRANS
IF THE TRANS IS BAD HOW HARD TO CONVERT TO AUTO
Discussion Starter · #2 ·
:bump: :bump:
Pilot bearing or worn gear teeth :dunno:
As far as a tranny swap to an auto, it's a pain in the a$$.
I,ve done it on a couple 70's muscle cars and I'd say only do it if your wantin a project otherwise sell the truck and buy one with an auto. :thumb:
well i kinda have been having trouble with the clutch but would that allow the stick to go to far and be in a gear when the stick is in nuetral
hmm... does it pop out of gear. If it is only problems going into gear I would think maybe it is just the wear pads on the shift forks...
Converting from manual to auto shouldn't be too hard. Another member here had a post about converting his... I'll try to find it..
I don't know man, hopefully somone with a little more knowledge on this will chime in.
That trans is pretty easy the take out, could take to a shop so they could have a look see, and check those cluch components out.:thumb:
Discussion Starter · #7 ·
NO IT DOSENT POP OUT OF GEAR IM JUST WORRIED ABOUT THE STICK ITSELF TRAVELING TO FAR AND THEN HOW WHEN ITS IN FOURTH AND IT WILL ACT LIKE ITS IN NUETRAL AND IF YOU PULL ON THE STICK MORE YOU CAN START TO FEEL THE GRIND LIKE TRYING TO STICK IT IN GEAR WITHOUT THE CLUTCH
Discussion Starter · #8 ·
:bump: :bump:
YOu said you were having problems with your clutch.
Could it be maybe that the clutch isn't dis engaging whenever you push the pedal in, and vice versa?
I was going to ask you if the shift lever itself was real sloppy in the top cover or if it was tight, right up until you said this. I've seen shift levers so worn they could hardly be shifted, felt like you were everywhere except where you should be. Bent, worn, or broken shift forks will cause these kinds of problems too. Any metal in the trans fluid or have you checked yet.
Discussion Starter · #11 ·
NO HAVENT CHECKED THE FLUID BUT SOMEBODY TOLD ME THAT WHERE THE SHIFT BALL ON THE END OF THE STICK GOES INTO THAT CUP THERE IS SUPPOSE TO BE LIKE A PLASTIC OR WHATEVER IN THERE TO TAKE UP SLOP WELL THERE SNT ANYTHING THERE AND I UNSURE IF THERE IS ANYTHING NEEDED TO BE IN THERE..... YOU THINK I COULD BE ABLE TO TELL ANYTHING BY PULLING THE PTO PLAT ON THE SIDE AND LOOKING INSIDE IM ALMOST AFRAID TO DO THAT IN FEAR OF SOMETHING BAD
I don't know how the shift lever is set up on these trucks but we can find out. If my shift lever was real loose I wouldn't go ripping into my tranny just yet.
Discussion Starter · #13 ·
WELL IM NOT SAYING THAT ITS TIGHTER THAN A TICKS KIESTER ITS GOT SLOP IN IT FOR SURE AND WHEN I TRY TO GET INTO 5TH IT ALMOST FEELS LIKE THE STICK ISNT GOING FAR ENOUGH
I've seen them get so sloppy you could move them several inches before they felt like they contacted anything and that kind of slop will cause problems. Actually there are several things that can cause these issues but shift lever and shift forks is right at the top of the list. Try looking up some info on your tranny here
https://www.motorcraftservice.com/pubs/content/~WS3O/~MUS~LEN/20/S3OMAIN.HTM
This is a little newer but they should be pretty much the same for the most part, at least for getting a DX anyway.
Discussion Starter · #15 ·
OK ILL LOOK THROUGH THERE AND SEE WHAT I CAN FIND IS THERE ANYTHING ELSE THAT COULD BE THE CULPRIT
most likely it is the lever, fork or a shift rail problem, I would give that lever a careful looking over. Did this problem just happen all at once or has it been steadily getting worse?
Discussion Starter · #17 ·
ALL AT ONCE BUT IT DOSENT DO IT ALL THE TIME NOW ITS JUST INTERMITENT
There is suppose to be two plastic bushings in that cup. Did you take the shifter out of that cup? Those plastic things are what the shift lever pivots on.
Thanks dsnodd, I had mine apart a few months ago but I didn't pay any attention to what was in there. I was gonna go take mine apart again so I could see, when my phone quits ringing.
Discussion Starter · #20 ·
ON THE PART THAT YOU TAKE OUT OR THE PART IN THE TRANNY IM TALKING ABOUT THE CUP ATTACHED TO THE RAIL IF SOMEBODY GOTTA DIAGRAM THAT WOULD BE HELPFULL OR PICS OF THEIR TRANS WITH THE HAT OFF IT
1 - 20 of 44 Posts
