1 - 1 of 1 Posts
· Registered
I have a edge evo ht for sale. it is slighly used. i purchased the tuner on NOV 2 2013. it works great and adds alot of hp for the price. i am selling it becuase it does not allow me to delete my dpf or egr. I purchase a mini max and did the egr deleate as well as a dpf delete.
EDGE EVO HT PROGRAMMER-TUNER FEATURES
■Available for 2011-2012 Ford 6.7L Powerstroke Diesel Trucks
■Adds up to 80 horsepower and 138 ft-lbs of torque
■Calibrates to Ford's most recent updates
■Three tuning levels (Performance, Mileage, and Tow)
■Selectable shift levels (Mild, Wild, Stock, and Edge Optimized)
■Torque Management Removal
■Adjust Speed Limiter
■Improves fuel economy and towing capabilities
■Adjusts for non stock tire sizes and displays true speed
■Transmission tuning to optimize shift points and firmness
■Fan temperature On/Off control
■Installs in minutes with no tools required
■SCAN TOOL/DIAGNOSTICS
■The Evo HT is a full functioning Scan Tool that reads and clears diagnostic trouble codes
The EVOHT programmer has the ability to remove/adjust your vehicle’s factory speed limiter. Improper use of this feature could result in a serious or fatal accident. Removal/adjustment of the factory speed limiter is intended for use in a closed circuit, legally sanctioned racing environment. Even if racing in a legally sanctioned racing environment, it is your responsibility to ensure your tires and other vehicle components are rated to travel at increased speeds with the speed limiter removed/adjusted. If you remove/adjust the speed limiter during highway driving, it is your responsibility to obey all driving laws, including adhering to posted speed limits.
EXPANDABLE TUNING
The Evo HT contains advanced tunes which are available for download and purchase on Edges internet update site including:
•Tunes compatible with hard parts such as cold air intake, exhaust, air filter, and throttle body spacers.
•Advanced transmission tuning to further adjust shift schedules and parameters within each shift point.
INTERNET UPDATEABLE
The Evo HT is internet updateable via it's built in USB port. Simply plug it in and update your Evo HT for the latest updates, software, and calibration files.
1 - 1 of 1 Posts
