1 - 14 of 14 Posts
How many quarts of ATF does the 6.4L tranny hold?
dropping the pan, or full flush?
dropping the pan.
I'm installing my Suncoast direct solenoid and I just dropped the pan but there 7 solenoids in there...which one am I supposed to change out?
Alright thanks. I figured it out. Is it alright to use dextron mercon III?
owners manual calls for mercon SP ATF
what's the difference?
would putting mercon III in there hurt it?
I just read somewhere, yes. You want to use the SP. I believe it's synthetic or semi-syn.
Just my 2c...
Ok thanks yall
You definitely need the Mercon SP. The clutches are not compatible with the older Mercon III.
my other concern would be is that he hasnt flushed the trans, so he'd be mixing different fluids
Good point. :thumb:
Discussion Starter #14
Haha thanks guys. I figured it out. I went and found some SP. And I did end up pulling all the solenoids and filter and did a full flush. But I didn't put III in it. And it's running great now btw. Thanks for all the help
1 - 14 of 14 Posts
