1 - 15 of 15 Posts
So i know that there is the 6.4 banjo bolts and then the 6.4 blue spring mod both for the fuel. I was wondering if there was any other 6.4 upgrades that can be done on the 6.0 thanks for reading
Tailgate, mirrors, rear diff cover.
WWW.COMPIGNTECH.COM
It's an upgrade the 6.4's is stronger it isn't exactly a direct bolt on replacement swap. River City Diesel has one that they sell with a kit so that it makes it a direct bolt on swap.
I say it doesnt count then.:haha:
The op did.
Lol
The blue spring is not a 6.4 item... it is actually made as an update for the 6.0!
Just an fyi so you would know.
Also, zoozad mod, high idle mod.
Lol
yup true story
I'm looking at potentially tapping the 6.0 block to the 16mm head bolts of a 6.4, and using 6.4 head studs. This would really need to be an out of the truck process to be right, but might be worthwhile.
I've entertained the idea of trying to swap 6.4 heads onto a 6.0 block...same pattern, and same 20mm dowell pin that the later 6.0's have. You could use the same 14mm head bolts on the 6.0, but iirc the 6.4 rocker boxes aren't bolted through the head bolts like 6.0's...been a while since I've seen one assembled. Obviously this would be a huge undertaking, and would probably be better off swapping in an entire 6.4. There's the wiring, the fuel system, and the computer that'd have to be changed, just at a minimum. The main reason of entertaining the idea was to obtain the 6.4 fuel system, quieter, and from what I've gathered, more efficient. be interesting to see how that all would work with 6.0 stuff...I have lots of time to think at work...If only I was a millionair
WWW.COMPIGNTECH.COM
Gearhead you took my ideas right out of my head. What are you psychic? Lol I have been trying to figure a way to convert a 6.0 to a smaller dispacement 6.4 or at least the commonrail fuel setup and maybe even the turbo's. I agree it would definitely be a MAJOR undertaking but I think that if someone gets it right it would be one seriously BAD A$$ 6.0 with limitless options.
I would agree with you bryan a 6.4 flywheel torque converter and 5r110 would be an upgrade as they do bolt right up. These trannies were built beefier to make up for the ponies, or so ive read.
Yeah man, bigger valves, same head bolt spacing, same valve/rocker geometry. I think pushrods are different length, only by like .020" or so, I can double check. I know the 6.4's have a higher valve height, 6.0's are like 2.220, I think 6.4's are like 2.300. That could be fixed with the right length pushrods, and or rockers from the right engine, or even Elite diesels adjustable rocker arms...although that ads another 3 grand to the cost. For the trouble, probably better off just swapping an entire 6.4...but honestly, I'd take a 6.0 over the 6.4, except for the fuel system. 6.4 blocks have way thinner castings, and for some reason wear out the valves more it seems like.
I wonder how long it'll be before 6.7 trucks are cheap enough, or they're enough of them wrecked to make people want to try to swap those in...that'd be possibly a bigger undertaking. But, hell, if people can get a cummins to function why not?:icon_ford:
1 - 15 of 15 Posts
