Helmet Automotive tire Sculpture Sports equipment Material property
Have pretty good power loss and builds boost way easier then it should, feels like there’s a boost leak, but there is also this white residue on the front of my air intake that looks like coolent, plus occasional blows out coolent from degas cap, any ideas would be great
Sounds like blockage/back pressure. You’d get less boost if you had a leak.
If your egr or intake manifold are blocked, you could experience over boost symptoms.
I would also check the dpf or flush it to make sure it’s not also blocked.
