1 - 9 of 9 Posts
My close friend has a 2008 F250 6.4L with 32K miles that is stuck at a jobsite currently because this evening when he went to leave, the truck wouldn't start...wouldn't even crank over. He got in, waited for glow plugs, then tried to crank...NOTHING, no attempt to crank. The passive anti-theft system light is flashing on the dash rapidly now too. If you wait for 30-45 secs the flashing slows down. We tried using both of his keys, no luck. We tried to jump the starter directly from battery on the passenger side (used plug by pass battery and air intake box. It would crank crank crank constantly, but never start. Check the fuel, not gelled. Truck has been fine without any issues ever! The truck does have a DPF delete AFE exhaust system with all DPF sensors plugged in and installed in the exhaust system. The truck is tuned by a H&S Black Maxx tuner and has been for probably 8-10 months (approx 7-10K miles). Never one issue. Now all of a sudden this. One odd thing is the Black Maxx tuner will power on, but that is it. Nothing is working/functioning on the tuner. Try to press a button and nothing. Display is powered on, but showing nothing at all gauges wise or anything. Since the Black Maxx will not function, we have no way to check the DTCs, read or clear them. All of this just happened about 5:30pm this evening and we have tried everything we could think of and that we have found by searching on here. It's too late to contact H&S tonight but we will in the morning. Tried to disconnect both batteries for a few minutes, no help. Anyone have any ideas at all? Any suggestions? Possible high pressure fuel pump? ECM? PCM? Any thoughts before we have to tow the truck to the dealer with all the exhaust and Black Maxx on it? Sure that will not help warranty coverage! haha. Any help would be greatly appreciated!
If your ANTI THEFT is flashing rapidly, that means there's a PATS issue....Which means either the transponder is messed up, or there's a computer issue. Good luck, and keep us posted!!
We've bought these trucks wrecked with the anti theft rapidly flashing and Ford told us that we needed to buy another programed key and have one in the ignition and one to unlock the door or some BS. We didn't really believe what they were saying though and just cranked it (manually the same way you did) and compression tested the motor. Then we junked the truck. They say though that there is something special you need to do to get those trucks out of anti theft.
Did you all figure out what was wrong? I know this is old but my 2008 (I just bought and drove off a transport) Is going crazy. In and out of limp mode, then when you shut it down SOMETIMES the anti-theft light goes crazy and you can't start it. It's a mess.
I just replaced both turbos and while it was accessible I replaced the glow plugs. in order to remove the turbos we had to remove a lot of things. Now we have it back together the anti they light is blinking really fast and its dead. The batteries are fully charged but nothing happens when you try to start it. Any suggestions or does anyone know what the problem is?? thank you for your help!!
either you need the keys reprogramed our you are not getting the program installed right. my wife has talked to owners of h&s they are still under gag order. mine ended up being a trashed flex plate and torque converter after thinking it was just a starter. it may just need reflashed either way I hate to say it may need to go to mechanic. I am putting a cummins in mine after the motor goes
1 - 9 of 9 Posts
