1 - 14 of 14 Posts
Just rebuilt my 6.4 and I replaced the rocker arms and the lifters and push rods and had it hook up to the Computer for diagnostic and it’s says everything is fine
That is a rocker noise, need to take the covers off and see which one -- you can use a hose by your ear to locate the noisy one -- likely a bad lifter
Just put the Second set of rocker arms and lifters in last Friday and still doing it
Did you have the valves reseated? Gonna need to check the stem height and required push rod length - may need a custom push rod or re-do the valves
the sound is excess clearance in one of the rockers -- since you have already changed the lifters again, likely can rule that out
How well do the lifters fit in the bores? excess clearance can rob oil used for the lifter operation -- low oil pressure in the lifter galley can also cause the "pecking" sound -- AKA Dodge Hemi lifter noise
Lifters fit good and the valves is the only thing I have not done yet
Use the old hose method to locate the one making the noise -- likely number 6
May be off base, but just when thru this with a Hemi, so I may be overly sensitive to the noise -- increasing the oil orifice size helped, but wound up replacing the engine -- the new engine after about 10k miles is ticking also
Will try tomorrow
Was think about just pulling the heads and have them redone to see if it’s the valves
Locate the noise first, so you know where to look for a problem -- even with the covers on you should be able to get a general location
"use the hose Luke"
It’s on number 4 or 6 Cylinder
Going to pull the head this week and have it looked at
6.0 Powerstroke n00b
Sorry to ask the obvious but where you posted "rebuild" could you be more specific about what was actually done? "Rebuild" means different things to different people. To me it means complete disassemble, machine work, measuring every part and clearance, along with more than I can list. Was the camshaft replaced along with the valvetrain? Were all measurements taken and recorded during assembly? I hate doing things twice.
Discussion Starter #12
Had the block bored 30 over and put new pistons in connecting robs and crank and cam or original parts
Put new lifters push rods and new rocker arms
What prompted the rebuild in the first place - maybe that would help to understand the problem
1 - 14 of 14 Posts
