2005 F350 CCSB, 7.3 fan clutch, Riffraff CAC boots, 135a alt, deleted, studded SCT livewire ts
So I got the idea for this after needing clearance for my red-neck oil cooler idea and it has kind of taken center stage of my efforts in order to get my truck back on the road.
I’ve read multiple threads and searched Until my eyes bled for pictures of other installs. I was going to wait until I had it in and running but whatever here goes.
The manifold arrived today and I’ve already clearanced it for the oil filter and thermostat housing. I had to grind a little off the passenger side to clear the heater return pipe but that may have been from me messing around with the pipe to clear the alternator bracket.
I saw where others had retained the stock 6.0 alternator location. I figured the 6.4 bracket might be an option since a few people were able to use the 6.4 alternator on a 6.0. Sure enough it will bolt up with a little grinding to clear the heater return inlet. I’m going to try just flipping the ac compressor and bolting back up, if not I think I can swap it to something with the hoses mounted differently like a 2001 focus compressor looks like it might work. I bought a pulley for a dual alternator 6.0 that mounts to the crank in order to run a second belt as that’s where the bracket puts the alternator at now. I could have run one of the shortened alternators that are the same as the dual alt setup but I wanted to be able to get one with more amps.
I plan on making my own adapter/clocking ring to use my 6.0 intake elbow. It doesn’t look like it should be too hard to machine it out of a block of aluminum. I might even be able to make it cover the 45 degree angle difference between the two intakes.
Currently I’m in the middle of degreasing the hell out of the intake. I thought mine was bad, the one I got off eBay is filled with the thickest sludge that is somehow still able to smear anything that touches it.
Ok enough reading, now for the pics.
I have more if anyone is interested, I just decided to upload a few because of my phones connection.
