1 - 13 of 13 Posts
This 6.4 has 220000 miles on it dpf deleted at 50K. rockers snd lifters redone 100K. Headgasket done at 200K also egr delete I believe and also oil cooler bulletproof at 100K.
this noise started when I was driving down the road at 80mph with a 20 foot 10,000 pound trailer behind me in Cruise control and then the rpms went crazy and far passenger side glow plug connecter was blown out and so was most of the oil. Had it towed to my house and I filled it up with oil and heres the noise it makes. Any help would be appreciated. http://instagr.am/p/CDYArQwjNzu/
2008 Ford F-250 Harley Davidson 6.4 Dynamic Diesel stage 1 kit, ODD Intake, and way more. 馃挩
Can鈥檛 see the video, try uploading it to YouTube. Maybe it鈥檚 just my cellphone..
My glow plug harness popped out of my valve cover too, except my glow plug went with it lol, happened twice. Still don鈥檛 know the cause. But I had blown head gaskets, when I just took it apart. As well as my heads were cracked, from the intake valve through the glow plug hole to the exhaust valve.
Anyway you can get a power balance/contribution balance test done? Any codes that you can pull?
I can鈥檛 get any codes from it, I鈥檓 probably gonna pay to have someone pull the valve cover and check the lifters and rockers**
Hard to tell on these vids, but I hear air pulsing/hissing
and a creak/squeak toward the end of the vid
I vote blown head gasket -- but the squeak/creak I have heard before just before the engine locked up and threw a rod -- also have heard a similar noise from a blown head gasket
Like I mentioned, really hard to tell from the vid -- but you definitely have a problem
I鈥檓 gonna go from cheep to expensive it seems that the #7 spark plug might have cracked and is letting oil out. If the tip didn鈥檛 come off it then it鈥檚 a simple glow plug swap instead of a new motor.
Discussion Starter · #7 ·
Also the end of the video noise is probably because it was running without any oil in it it has leaked all out of the tip of the spark plug had just fell.
You keep saying spark plug, you realize you鈥檙e on a diesel forum right?
Thinking this may be a problem
"noise is probably because it was running without any oil in it it has leaked all out "
1 - 13 of 13 Posts
