Ok, pretty sure my dpf was getting clogged. Usually remove after yearly smog and run dpf delete tune.
I recently got a motorcycle so very limited driving, thought I would leave it in until after smog next year.
So, I clear the egt temp errors right away and thought it should start. No joy.
Reinstalled tune with delete to see if that would bypass the problem. Nope. 30 minute battery disconnect to clear pcm. Still no crank.
I hit the fuel reset passenger side rear of glovebox.
What am I missing? Disconnected the entire sensors in the back 2/3 of exhaust, passenger downpipe still connected.
Some other limp mode to reset? Plenty of battery, fuel pump comes on with key.
Administrator
No crank seems like an electrical or key sync issue.
are we sure the truck is recognizing the key and disarming the security system?
I can do everything except crank. Whole truck seems normal, except crank. Like some dumbass setting prevents crank. It behaves like there is a code that says "no crank" everything else seems normal. I hear a relay in glove compartment area click when I turn to crank starter.
My problem sounds the same as this one:
