1 - 20 of 66 Posts
wondering which one i should get and what the differences are??
thanks
I have a downpipe back 5" with no muffler and you can barely hear it in the cab. With the windows down you can tell its there.
thanks
any difference in performance or mpg??
I run 5" with an Aero Turbine muffler and to me it sounds great.
definitely no muffler! the cab noise isn't bad at all, but outside it sounds freaking awesome!
No change in MPG or performance. It will help lower your EGT's a bit, and give the truck a really nice tone when getting on it. Thats about it
Discussion Starter · #8 ·
ok thanks one more question
i had my dad order all this for me and he said" if its loud im gonna be pissed"
sooooooo??? am i gonna get my *** kicked or is it not that bad at startup and idle???
If you don't tow straight piped sounds good, I put a muffler on mine after a few trips towing.
It's not bad. These aren't Cummins. 5" is the only way to go. If it's too loud, I recommend getting the FTE Diesel resonator.
Your a$$ should be safe from a whoopin. It has a really nice tone to it at start up and idle. Not loud at all. He will be happy with the results. If the windows are up in the truck you wont even know you changed anything while cruising down the road.
Discussion Starter · #12 ·
thanks
whats the resonater do??
I have a thread here on the forum about it with videos. Do a search for FTE Resonator and the thread should come up. Make sure it's the thread that I started on it.
Discussion Starter · #14 ·
sounds good!
i likee the sound of exhuasts that whistle. will my straight pipe whistl loud?
No. Not really loud, but it's a good tone.
It's not really going to whistle cause of the twins, but it will sound like a freaking jet going down the road.
I just installed a flo pro 5 in. Back kit and couldn't be happier with the sound. It sounds great and isnt too loud! I actually would like it a little louder!
Dont Mess With Texas!
you will be safe its not loud at all sounds like a jet engine real airyy
sounds good!
not much whistle on the 6.4 like 08spartan250 said because of the twins it does have quiet a turbo sound when you let off the skinny pedal runnig down the highway
i second that motion i put a 5" system on my i still havent put my tip on i need to cut the end of the exhaust and fit my tip on
i picked up a 5" x 6" MBRP stainless Dual Wall for an 18 pack of coors light so its sitting in my garage
^ I put the same tip on mine and I love it. My only complaint is that its really close to the bed of my truck . I need to cut some more off so its at more of a downward angle but I absolutely love the sound. I was on the highway today for the first time and at 80mph with the windows up I could barely hear it and with the radio going I couldn't at all!
1 - 20 of 66 Posts
