truck threw these codes
P006B
P2563
P0087
U3F25
its -30 truck wouldn't start. got it in a warm garage to let it thaw and began to drain the water separator on the frame rail after a hour and a half of sitting. I drained 1/2 gallon of crap out of it and let it run. the check engine light then went out. I drove it for about an hour and the check engine light came on with this code
P2536
I popped the hood to find coolant all over my reservoir. My boost seemed a little higher than normal also. one of those codes are for the EBP sensor witch I replaced 2 days ago! WHAT DO I DO PLEASE HELP!!!
P006B
P2563
P0087
U3F25
P2536
