1 - 14 of 14 Posts
BUILDING PRESURE IN COOLING?
COOLANT TEMP 180-200 BLOWING OUT OF RESIVOR
NO OIL IN COOLANT OR IN OIL
OIL TEMP 200-230
:dunno:
I HAVE SINISTER EGR DEL. ON TRUCK NOW
DONT HAVE ANY LOSE IN COMP.
DID HAVE A DTC BUT CLEARED NOT BACK OF #4&8 CONTRIBUTION/BLANCE
6.0 from ****? Sounds like someone needs some maintenance along with knowledge first.
That is a high ECT/EOT delta. Oil cooler possibly.
How high is the coolant level when cold in the degass bottle? About 1/4" below min is new max.
WWW.COMPIGNTECH.COM
Oil cooler will NOT cause puking. Cracked EGR cooler or blown head gaskets will. A cracked oil cooler will leak oil into the cooling system.
If you have an EGR delete your looking at a head gasket job. Get ready.
I've been haveing problems this truck since bought used last nov. has 210, on it now
open for sugestion/ advice on what to do.
1. Should I do head gasket job with a solution kit
2. Find used motor up grade it befoe install
3. Buy crate motor all ready done up
Thank you
I made my own kit with River City Diesel they we're great and gave a good discount since I bought everything from them
Check them out
Sent from my iPad using AG Free
do an EGR delete and more than likely you will be doing head studs...
EDIT: and with oil temps reaching 230 replace the oil cooler while your in there.
oil cooler was first thing went out on truck cost me $3,200.00 @ ford house done in jan. this yr. I aready put to many miles since for it to be coverd by waranty and egr went out in april installed delete my self . I've just orderd a complete solution kit sinister thanks for advice
Does it build pressure when you start it (need gauge) or after it warms up.
My 04 is doing that so I am doing everything but heads, unless I find something during disassembly. Might go after heads if I am that close.
1 - 14 of 14 Posts
