1 - 2 of 2 Posts
Vendor
Many 6.0L & 7.3L Powerstroke owners have experienced the somewhat common issue of coolant degas bottle failure. Leaking oil coolers and cracked cylinder heads often contaminate the cooling system with engine oil or diesel fuel causing the reservoir to soften and swell - often to the point that the cap cannot even be reinstalled. Because the factory tank is an integral part of the pressurized cooling system, rupture of the tank will cause catastrophic coolant loss, engine overheating, and potentially a towing bill.
Our aluminum coolant tanks are fully tig welded and much stronger than the factory design as well as being totally impervious to oil and fuel for greater peace of mind. Each 6.0 & 7.3L Powerstroke degas bottle is powder-coated to really set off your engine compartment and includes a sight glass for confirming correct coolant level. An additional 1/8 NPT port is added for monitoring coolant pressure or temperature if desired. This should be the last degas bottle your truck will ever need!
These are just $199.99
6.0L Powerstroke Degas Tank
7.3L Powerstroke Degas Tank
If you need one of these tanks just message me directly or give me a call.
Regards,
Tommy T.
(941)451-2826
1 - 2 of 2 Posts
