1 - 1 of 1 Posts
05 f350
I’m stumped, I decided to replace my oil cooler after notice my engine temp was 192 and my oil temp was at 263 .
This was not my first replacement .
After replacing oil cooler and a few other minor things like , new thermostat , upgraded blue fuel pressure regulator spring, etc..
Beside oil cooler ,truck for the most part sounded and ran fine until I parked it to do oil cooler .
After job was all done , truck would not turn over and it does not sound good , sounds like no compression and it won’t turn over , I don’t understand how a some what of a simple job, engine is toast . How is that possible ?
Error codes
P1000
B1343
B1352
No check engine light
Repaired or replaced :
IPR
ENGINE HARNESS
GLOW PLUGS
GPCM
PCM
GLOW PLUG HARNES
FICM HARNESS
STARTER
BATTERIES
Ficm main power
48v
ICP 193
IPR 14.85
No sync
Cylinder 4,6,8
60psi
1 - 1 of 1 Posts
