1 - 20 of 24 Posts
I have seen instructions for a 6.0 cooler on superdutys but never any obs trucks. will it still work? Is it a direct bolt on replacement or do you have to mod stuff? Will the 32 row fit on it because i can get one for $150.
Diesel Freak
Grab it quick that's a great price on a 6.0 cooler shouldn't be too hard to mount and adapt for an OBS
The reason is because I am having a ford tranny guy rebuild mine and I didn't know if it was a direct bolt on. how hard is it? What will I need?
Not a direct bolt on as the factory trans cooler goes through the radiator, they are usually mounted in front of the radiator or i think some have put them in the bumper
So does the trans cooler just plug into the old lines?
All thats really needed and will cool fantastic is a Trucool and swaping to SD 3/8" lines.
Mount the cooler on the back of the bumper.
SD trans lines
Line F81Z-7A031CE
Line F81Z-7A030CA
By Pass Tube 2C3Z-7H322-BA
LPD47391 Tru-Cool
Discussion Starter · #7 ·
Will I have to open up the trans to do it?
Delivers Pizzas For Fun!
The SD coolers are huge and cool well but the tru-cool units are a much cleaner install and cool very well
Forget the TruCool, it's smaller than a 6.0. Get the 6.0.
Guess it depends on what it's going to be used for and how much the truck weighs.
A 6.0 cooler is good for 40,000lb gvw rating... tru-cool maxx = 40,000lb gvw....
Specs are specs.
Hillbilly Deluxe
FWIW i have had both in 2 different trucks and haven't noticed any differences in cooling...
Discussion Starter · #16 ·
So let me get this straight, I can get a tru cool for less money then a used 6.0 cooler, with the same performance. Also, the tru cool is better since there is more room for an intercooler?
Correct..this is because of where it mounts on a OBS, SD use the 31 row cooler..that goes in place of the stocker thats behind the A/C coil.
Don't forget to upgrade to SD lines and bypass.
Discussion Starter · #18 ·
Okay, so I looked at them and there is an option for a sd install kit. I assume I would not need this since the mounting points can be used from my stock trans cooler?
Hillbilly Deluxe
Your stock cooler on an OBS truck is a few loops in the RAD. FWIW i will be going with the truecool on the dually build.
1 - 20 of 24 Posts
