1 - 8 of 8 Posts
hey guys maybe you can give me some insight on this, here's the story... it's all started about two weeks ago.. the truck is a 04 stock with the srl tune from gearhead.. this has happened only twice but when I am between 3/4 and full throttle the truck will stop pulling and rev out to about 4k rpms. then I put it in neutral and stop and put back into drive then the truck will take back off fine with no hesitation.. I have noticed no shift flares hard shifting or any other tranny problems up to this point.. do you think this could be a torque converter going out or what? I am going to change the fluid and change the filter ASAP and see if this does any better.. any insight would be greatly appreciated
thanks
zach
Administrator
does it do it with out the tune? Try unhooking the batteries and resetting the truck so the trans can re-learn.
nope didn't do it today with it on stock.. I pulled our 25ft gooseneck with a 13k pound tractor and nothing went wrong at all.. surely it would have stopped pulling again with all that weight but it didn't.. kinda confused??
1 - 8 of 8 Posts
