1 - 5 of 5 Posts
· Registered
Looking for some help with standpipes. I’m on my 3rd set in 12 months I keep blowing the o rings. I’ve replaced with AVP updated one but they keep failing, just curious about what could be causing this and if I should just get the motorcraft ones. I keep using the avp because they warranted them each time. Thanks in advance. 2006 6.0.
777392
· Mr. Crossthread
Get Motorcraft and use a good assembly lube on the o rings during install.
Sent from my SM-G991U using Tapatalk
· Mr. Crossthread
Oil is usually fine but since you're having issues I'd go the extra step.
· Premium Member
Sharp edge on the branch tube, and you are cutting the oring when it is installed
Do not soak the rings in oil -- they only need oiled just before installation -- the rings can swell from being in oil, that is part of how they 'seal'
1 - 5 of 5 Posts
