6.0 P0404 Engine Code
3436 Views 45 Replies 3 Participants Last post by  Mitchellgrawe
So here we go, first off I am not sure if all of these events are connected or just problems unrelated but I think they are. I was driving to one of my customers houses and I got P0404 engine code, (also was blowing a bit of black smoke but no a lot) drove to where I need to be and having a cheap scanner I saw it was EGR related so I pulled the valve and the o rings were chewed up. Neither one was gone but the bottom one had a good tear but was still in tact. So I replaced the o rings and felt it seat it and I even used a bit of oil to lube them up. It worked for about 4-5 days and then booms engine code again P0404 (no smoke this time)…so I replaced the valve altogether and reset the code….I didn’t notice much of a change. I don’t think I have drove it long enough for it to read a check engine light heat, about 70 or so miles. But two weeks prior to the o rings being chewed up I was driving a dump trailer loaded down probably weighed about 7-8k total coming down a two lane highway and I was going to cross over to an access road and as I did this boom no trailer lights. So I pulled over and to me the truck was running different than before. I looked under the fuse boxes two days later and sure enough two fuses had blown, 38 and 4. I also notice a sort of chatter upon acceleration that is harder than before. I pulled the air intakes to take a look at the EBP sensor pigtail and one of the pins was black as the other two were copper looking. So I replaced the pigtail and the engine tan great I started to hear that turbo really whistle and felt the power then poof I made one turn into a neighborhood then it started back again…I ordered an new EBP sensor and I will update if that changes anything but I suspect it will run well then it will acclimate to the computer and run rough again just guessing. Too I pulled the VGT solenoid and the connector broke inside the solenoid like the plastic bits so I quickly plugged it bag inside and order a new pigtail. No difference there but i figured that was a good practice to prevent future problems there. Now one thing to highlight is that I keep getting the SH code from my trailer brake controller making me think I still have a shirt somewhere but I looked and looked but can’t find a bad looking wire. Both batteries are good and alternator is good. I just bought the truck about two months ago and it was running great and then the trailer thing happened… which makes me thing it is possible the trailer had a bad ground and fried a bunch of parts in my truck. I replaced the fuel filters that they had in them that weren’t oem with oem ones along with oem oil filters and changed the cap back to the OEM. Too I replaced the CAG boots on Botha ends as they had one small non stock blue tub on one side and what looked like a ford one on the other side but I still replaced both. Please help, I will update what the EBP does. Let me know what y’all think.
See less See more
21 - 40 of 46 Posts
I have the Hyper tough scanner will it do what you are asking? I can read engine codes
These three I have found. I want to do the cheap one but if I have to I’ll buy the $70 one. But $120 for a scanner is it really different than the others?
again - are you putting it on an iphone, an Android, or a laptop?
I’m asking will I be restricted with an iPhone?
The full version (which can do quite a few tests that the Lite version can't) is for a Windows laptop only.
The Lite version for the Android and the iPhone work essentially the same.
The money spent on an adapter will dictate how quickly the data transmission is, update rates, and maybe a few other features that most people would never even notice if they had it,
Even though ForScan is phasing out the EM327 support, my BAFX (ELM) WiFi adapter works fine with my iphone and it is $36.
I'll bow out now. Lot of (better) things to do .............
I'll bow out now. Lot to do .............
EBP sensor I bought doesn’t look like the one I have in my truck but it says that it’s for the year of my truck…
That one is the one I bought and when I pulled It looked like this one…
if you say you don’t think it’s that I think i will send it back and get the reader you referenced. Should be here over night
See less See more
Buy only
Genuine Motorcraft sensors. I cheaped out and bought a generic EBP sensor and it didn't even last two weeks.
Reactions: 3
Buy only
How do you check for Map and baro? I got the bafx Wi-Fi adapter. I also have Forscan lite on my phone do I need a computer?
You should be able to select them as a PID. but I'm not sure, I haven't used Forscan lite. I have the full version used on a lap top. I would think the lite should monitor them.
See less See more
2
Okay I’ll do that when I’m parked I posted all the codes o was getting. It’s amazing with that cheap thing I got nothing but $25 more and now I’m reading all this. I’ll be doing research this afternoon
Reactions: 1
Key on truck off this is what they read I’m not sure if this is what you are asking for.
See less See more
Keep an eye to see if the injector code comes back...that could be part of your problem.
That middle baro at 4.5 v looks suspect to me. But I'm not too sure on the 03/04 motors because they are different with the EBP. Mark would know better.
What about all the other codes? I think I have an electrical problem that has progressively gotten worse. Not sure but I know my truck isn’t running quite like it should. Brakes feel weird, putting my foot on the pedal feels off. All those electrical codes man. Is there a way to pin it to one harness or anywhere I should look??
There are a few common places to look at the harness. Under the air box, the connectors on the driver's wheel wheel isn't common but good to look at. And obviously check your grounds.
Man I am just thinking I flushed the coolant wrong.. i went to change my coolant recently and I used ford gold coolant. When I did this everything ran fine, I obviously knew there were some electrical issues but I don’t think major ones. But I drove it for a bout a week and I had been checking my coolant levels frequently by just rocking the Truck a bit and noticing the coolant. I checked it the following week if the change and it went pretty low, like coolant was. Barely above the bottom of the bottle… so I added some coolant. Then it drove okay but still not great. Fast forward about 2 weeks to this morning and my coolant was wayyyy above the max fill line. I mean I was shocked. So I took the mount bolts for the degas bottle off and poured some out the top through one of the top hoses tilting the bottle a bit until it was in the upper fill line cold. Again the Tran tan good for the first half of the day, started shifting better again and had solid acceleration again. Then after the day went buy and I drove about 100-250 miles the coolant level has gone back down under the cold min line while the truck was running. I’ll wait to see where it is at in the morning and I will see where it is at when the truck is warm. Also I will post the video I followed of how to flush the coolant.
one thing to mention, coolant looks and smells fine. I am wondering if I should just go get it pressure pulled and filled by jail kar with there coolant they say is for all vehicles or bringing my own to them. But my fear is that the reason coolant level is fluctuating it is getting stuck somewhere and if the pull the coolant there pressurized system will not pull the coolant where it is stuck from and then we will be mixing two types of coolants. HELLPPP PLEASEE
See less See more
You can take everything Bill says with a grain of salt....some is good, some not. You will find that many will never allow Ford gold in their truck. Having a vacuum filled coolant system is nice, but not necessary on the 6.0. it does sound like you do have an air lock somewhere though.
I would pull your intake off so you can look the loom over in the valley and the harness everywhere you can see. Don't forget to check the grounds and your ficm connections.
Take your time do a good visual inspection and thorough cleaning of all grounds and terminal connections.
Also don't forget about your previous injector code. That could very well be your problem. I have at least one bad injector and it only coded once and never came back.
You would be money ahead by having a contribution test done by a shop or the dealership. After a wire inspection that would be my next stop.
See less See more
Am i okay to drive in this condition of allow coolant? I had the air filter of yesterday and I didn’t see anything that jumped at me. I will look again. The coolant I think I will go get changed. Is this right? Or this air bubble won’t hurt my truck? Low coolant? I have been watch ect and eot and when I was in the highway max I saw was 11 spread which I know is high but it didn’t stay for long
I wouldn't drive it like that, I would drain and refill, but I am a better safe than sorry kind of guy.
So is this kwik kar any car coolant okay or should I get some red elc and ask them to us it?
21 - 40 of 46 Posts
