What model year?
2004 F350 4x4 srw 8ft bed crew cab lariat 6.0 power strokeWhat model year?
I am guessing next to the turbo behind the ficm and degas bottle I was in there yesterday I guess I can check that out. My ebp sensor came in so I’ll be installing that tonight.So, the 2004 could have had the 2003 engine installed. Next question - where is your ICP sensor located?
I know I have an ebp sensor…If your ICP is behind the turbo, then your model year strategy (03) does not even use the EBP sensor .........
I just replaced the pigtailI know I have an ebp sensor…
You need a very good code reader to pick up some of the Ford codes. Average scan tools and tuners do not do a very good job.
Fortunately ForScan and ForScan Lite are excellent and are cheap. The full version for a Windows laptop is free (you do NOT need to pay for an extended license) and the Lite version for a smartphone is a $6 download. You do need an adapter - the USB version for the laptop and a WiFi for iOs or BlueTooth for Android. If you are interested, we can help you pick out a good adapter.
The inferred EBP strategy uses the MAF sensor, IAT2, and MAP sensor, and the VGT (turbo actuator) to properly control the turbo.
Since you have a new (and hopefully good) EBP sensor, use your scan tool to find EBP (may not be able to), MAP, and Baro at KOEO (key on - engine off), and post those values.
I forgot to mention my catalytic converter has a crack in it. I’m not sure if this has an effect on any of this. When I get home I will read more in Seth. I don’t think my scammer can read that. It was $15You need a very good code reader to pick up some of the Ford codes. Average scan tools and tuners do not do a very good job.
That's for sure, now days there isn't really an excuse not to have torque pro and Forscan or both. A $35 dongle and you're off to code reading.I am on pretty much all of the 6.0L forums and I think you will find that most people that are willing to help will now expect you to get ForScan or Torque Pro (unless you already have a more expensive and capable tool). It gets too expensive to guess and most people don't like suggesting things that are not fairly certain to help.
Okay I will look for one tomorrowI am on pretty much all of the 6.0L forums and I think you will find that most people that are willing to help will now expect you to get ForScan or Torque Pro (unless you already have a more expensive and capable tool). It gets too expensive to guess and most people don't like suggesting things that are not fairly certain to help.
I have the Hyper tough scanner will it do what you are asking? I can read engine codesI am on pretty much all of the 6.0L forums and I think you will find that most people that are willing to help will now expect you to get ForScan or Torque Pro (unless you already have a more expensive and capable tool). It gets too expensive to guess and most people don't like suggesting things that are not fairly certain to help.
What I am saying is that it may not read all the codes.I have the Hyper tough scanner will it do what you are asking? I can read engine codes
So Forscan, what do I buy, where do I buy?What I am saying is that it may not read all the codes.
I certainly am not familiar with all the options that exist today, but time-and-time again ForScan has proven to be more thorough than all but the Ford IDS system and several other high end systems.
What I read about the Autel HT is consistent with most cheap scan tools - it is not a thorough code OR PID reader.
I found the website with the lite and free version you were talking about. So do I get the lite free version or do I need the trial to read those other ones. Also for the scanner to usb can I use any available at a auto store? Would I be able to read everything from my phone if I got the IOS version?So Forscan, what do I buy, where do I buy?
