1 - 10 of 10 Posts
This morning I was doing 40mph and when I went to go around the car in front of me, I pressed the accelerator and I was still doing 40mph. Felt like I was getting no response as I kept pressing the pedal and I actually began slowing down with the foot on the gas. Then she came to, sputtered a bit and I pulled over. I put her in park and pressed the accelerator several times. I smelled something like a burn smell but couldn't see smoke as it was still dark. I let her idle for 5 minutes and then drove 8 miles to the office with no problems.
Two months ago, I had an issue that made me feel like my foot slipped off the gas (felt an immediate jolt stop and then kicked back in). I had it serviced and they said they found the sensor (not sure which one) was melted. She was fine until today.
Any takers on this problem? Much thanks!!!!!:confused:
<--Pro Cooler Racer
TPS (Throttle Position Sensor)? Maybe? That is the first sensor that comes to mind that could malfunction and "burn". Maybe a short somewhere the is toasting it, giving faulty response then eventual failure.
Have you had any aftermarket wiring or mods done in/under the drivers side dash?
Mine does that when it's time for new fuel filters. I call the lack of power my filter minder.
Thanks for the quick response Eric. I thought the letter "E" was in the three-letters before the word "sensor"? Does that ring a bell? No, I have not had any aftermarket anything done. I bought the truck with 40,000 miles and she has wiring for 5th Wheel and Goosneck hookups.
I am leaning towards this being an "electrical" issue more than a mechanical/parts issue.
Thoughts?
Justin,
Thanks for the response! I just had my fuel filters replaced two months ago, so that may not be it.
If it's not the TPS sensor it may be the EGR valve. Mine blew smoke and fell on it's face while accelerating.
Discussion Starter · #7 ·
The EGR Valve is what I have been reading on past postings as contributing to my same issue and I am beginning to agree with this. Thanks Audrey!
Just have about two cans of carb cleaner, a tooth brush, and a tig welder ready. (TIG welder Optional)
Discussion Starter · #9 ·
I never leave home without my toothbrush. I think I will tackle the EGR Valve and see if that fixes my problem. Thanks!
If your truck is an 03-04, you could tig weld the EGR valve and un-plug it from the harness without throwing a code. That's an easy way to remedy the problem.
1 - 10 of 10 Posts
