Welcome to the ORG! Sounds like your silicon boot is oil soaked. You might wanna try to wipe it down real good and then spray it with hair spray. After it gets tacky, put it back together and it should help pretty good. If not, you will have to replace it. It happens because oil is recirculated through your turbo via the CrankCase Vent; do the CCV mod and reroute the CCV, so this doesn't continue to happen.
