1 - 20 of 26 Posts
AMERICA!
Discussion Starter #1 (Edited by Moderator)
6.0 General Discussion Stickys
https://www.powerstroke.org/forum/94-98-7-3l-general-powerstroke-discussion/38816-anyone-who-needs-acronyms-ford.html
Link to 6.0 flush pdf https://www.powerstroke.org/forum/general-6-0l-discussion/general-6-0l-discussion/general-6-0l-discussion/att...flush_v1-0.pdf
https://www.powerstroke.org/forum/general-6-0l-discussion/204386-write-up-bullet-proofing-6-0l-psd.html
https://www.powerstroke.org/forum/general-6-0l-discussion/351594-fixing-stiction.html
https://www.powerstroke.org/forum/general-6-0l-discussion/279906-6-0-head-stud-part-list.html
https://www.powerstroke.org/forum/general-6-0l-discussion/192090-sct-device-questions-answers.html
https://www.powerstroke.org/forum/general-6-0l-discussion/238358-6-0-parts-list-ford-international.html
https://www.powerstroke.org/forum/general-6-0l-discussion/559985-banjo-bolts-myths-surround-them.html
https://www.powerstroke.org/forum/general-6-0l-discussion/449218-information-about-sct-devices.html
https://www.powerstroke.org/forum/general-6-0l-discussion/259257-write-up-monitoring-6-0l-psd.html
https://www.powerstroke.org/forum/general-6-0l-discussion/136360-new-preload-torque-recommendations-6-0-arp-studs.html
https://www.powerstroke.org/forum/general-6-0l-discussion/214603-what-look-when-buying-used-sct-6-0-a.html
https://www.powerstroke.org/forum/general-6-0l-discussion/267064-shes-under-knife-my-build-thread-lots-pics.html
https://www.powerstroke.org/forum/general-6-0l-discussion/465706-reconditioning-6-0-turbo.html
https://www.powerstroke.org/forum/general-6-0l-discussion/255144-iron-scale-experiment.html
https://www.powerstroke.org/forum/general-6-0l-discussion/271732-bulletproof-diesel-oil-cooler-install.html
https://www.powerstroke.org/forum/general-6-0l-discussion/246452-troubleshooting-coolant-loss-white-residue-around-cooling-system-components-degas.html
https://www.powerstroke.org/forum/general-6-0l-discussion/206316-paramedic-saves-6-0l.html
https://www.powerstroke.org/forum/general-6-0l-discussion/229120-how-machine-6-0-a.html
https://www.powerstroke.org/forum/general-6-0l-discussion/243743-started-big-bulletproofing-endeavor.html
https://www.powerstroke.org/forum/general-6-0l-discussion/50-stock-horsepower-torque-6-0l-powerstroke.html
https://www.powerstroke.org/forum/general-6-0l-discussion/347202-how-determine-head-cracked.html
https://www.powerstroke.org/forum/6-0l-problems-forum/236534-no-start-issue-look-here.html
GET MY ENEMA BUCKET BRO!!
Very nice. I like it.
Definitely cleaner. The only problem I foresee is that you won't know about new posts in these threads unless you are subscribed to each of them. Am I wrong?
AMERICA!
Hmmmm... I actually hadn't thought about that. This was the only good way I could come up with to clean things up.
DERAIL MOD!!!
How's about making it a sub forum similar to the e99 discussion forum?
Mitch
AMERICA!
I actually asked about making a sub forum but was told that there were difficulties setting one up. I will look into it again.
IMHO I like it. Things are cleaned up and pretty much know where I left off on each of those threads but hey that's just me
Agreed, much cleaner. I like it.
I have a 2005 ford excursion 6.0 with an egr delete kit i have been getting a po470 code witch is back pressure sensor. so I replaced it and the map sensor ran great fro 2 months now it is back. i have no power on take off and then it just takes off with full power and runs great. when i shut the truck off and it will start again. can any body help!!! dont know what to do!
As a new member and first time 6.0 owner, has any of the experts thought about developing a sticky that tells what all the different acronyms are for parts, sensors and the like are. Maybe include their function, importance, relationship to other components, how to monitor & check, etc..?
It would be a great help for new members and help cut the learning curve down.
I have searched for this but do not find it. If it already exists, I will take the heat.
Reactions: Tminit
The Maddawg
Isn't there a sticky for flushing an oil cooler? I can't find it!
Sent from my SM-J727VPP using Tapatalk
Reactions: Patriot and ZMANN
1 - 20 of 26 Posts
