2006 F-350. Replaced both fuel filters 2 weeks ago. Yesterday the truck shut off while driving, acted like it wasn't getting fuel. Removed the fuel line from the fuel pump outlet, turned the key on and got just a little spurt of fuel so figured it was the fuel pump. Installed a new pump and now I am still not getting any fuel out of the pump. Can anyone help with this?
No, filters not OEM. Got them from NAPA. The pump does run and I just filled up the tank. I just read on another post the the HFCM filter is suppose to have 2 o-rings. The filter I installed only had one for the cap. Could that be the issue?
With non-OEM filters, you just don't know. I would recommend that you swap those out and start the diagnostic process from there.
Reactions: RetiredFD
