1 - 2 of 2 Posts
Hello Diesel Guru's.....
I've been lurking for a while and trying to learn all I can. Here is what I've learned so far. MAKE SURE YOU DONT RUN OUT OF FUEL :doh:
I was pretty low and parked on a hill. I made a turn onto the main road and it died. I was able to crack the filter cap and relieve the air pressure to start the truck. It now runs a bit rough and has the check engine light on.
The truck is under warranty but I dont want to lay it up if not needed. I am due for service oil/fuel/air filters.
Any ideas, suggestions????
Thanks in advance and thanks for all the great tips I have found so far! :thumb:
Discussion Starter · #2 ·
Update,
Light went out after a few key starts.
1 - 2 of 2 Posts
