1 - 2 of 2 Posts
So yesterday I was driving and lost power. Like it became hard to accelerate and the truck started chugging almost. Rpms were up a little high while it was doing this. The truck died shortly after doing this, truck won’t start back up, it’ll crank but no start. Just did an oil change the day before. Prior to the truck not starting it sounded like it had some sort of leak, could hear it very well when accelerating. The best way I can explain the sound was almost a 5.4 triton exhaust leak. Has 190/30 injectors and a fass lift pump with a sump. Any ideas would be appreciated!
Same brand of oil/filter as before? Using an OEM filter? You know the drill - need some numbers (IPR%, ICPv, ICP, FICMv, etc. KOEO & while cranking). Until then, there's at least 10 different things that can cause that.
-jokester
1 - 2 of 2 Posts
