Do you have a way to monitor ICP & IPR? I had the same thing happen to me just last week. I rebuilt the 4 driver's side injectors, and when I went to start it, it wouldn't build ICP. Topped out about 75psi (needs 500 to start). Mine turned out to be one of the spool valves that I put in backwards.
I would start by monitoring the IPR and ICP. IPR should be ~85% cranking, and ICP should rise toward 500psi before it'll fire the injectors.
If you're not getting ICP, you have a leak somewhere. like I said, check the spool valves. They have to go in a certain way. Better yet, do an air test. That will narrow it down.
If it sounds like it's leaking at an injector, you can use a rubber tipped air gun in the top of them. A small amount of leakage there is fine, but when I had a spool valve in backward, it wouldn't hold air at all.
Hope this helps! Let us know what you come up with!
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
266.2K members
Since 2005
