36401 - 36420 of 36469 Posts
13mm mounting bolts, 10mm exciter wire nut, 15 or 16mm for positive cable.
Sent from my SM-A505U using Tapatalk
To add to waggonerj's good info:
15 mm for positive cable
First disconnect batteries, Then remove wiring nuts at the starter. Top 13 mm bolt (M8x 1.25) is hard! For that top bolt, use a 3/8 inch 6pt deepwell socket w/ 6 inch extension and a flexhead ratchet (or you could use a wobble socket).
To reinstall, you can zip tie the 6" extension with the 13mm socket already connected to the extension and mounted on the bolt so that you don't have to try to "find" the bolt head with the socket. The zip tie would go around the entire starter body.
Torque value in the WSM is 25 N-M (18 ft-lbs) for the mounting bolts, 53 in-lbs for the solenoid wire. and 9 ft-lbs for positive cable.
Use low-strength loctite 222 (at least on the on the larger bolt).
A bronze bushing from McMaster Carr will fill the 10mm hole if you want to use a 6.7 starter 8mm bore by 12mm OD by 15mm, also supplied by uxcell on Amazon
california deplorable
good luck brother, it's not that bad, from what i remember...
but i do remember some cussing and a smashed knuckle or two...
it was actually easier than i expected from what i had read before hand.
check over the grounds and power wire to the pass side battery so the new one doesnt go the way of the old one, you got this...
Mr. Crossthread
I couldnt remember, mine is 16mm so I always just take both with me. Lol
Today's entertainment
Sent from my SM-N950U using Tapatalk
I'd go with diesel for that rig
Nope that's just a quarter horse, definitely a gasser.
These are diesel rigs, 2nd one is for perspective.
The Palomino is a quarter horse. And Jack was still smaller than mom.
767245
767246
Works better if you ride them... Must have been out of fuel.
She was heading across the street to Haji's
Can I get just the accelerator pedal for an 04 or do I have to buy the whole assembly?
Helllll yeah. Some Texans just said our restrooms are better than buc'ees.
And I know how you Texans are about your buc'ees
high praise indeed
did you tell them to stay in California and not return to Texas?
Need to tell the Californians fleeing high taxes but bringing their stupid leftist ideology that Texas is closed.
Been trying that for years here in Idaho, hasn't helped.
Sent from my LM-G820 using Tapatalk
You can't stop us
Sent from my SM-G960U using Tapatalk
You can, just kinda really really frowned upon by management
@Flamed99
I think what's more of a problem is they are bringing their California incomes and pricing ideology of "how cheap everything is" and causing mass inflation for locals.
They are happy to pay double, because to them that's still half off
