1 - 10 of 10 Posts
Does anyone have pics of where this thing is? I cant find it....
<--Pro Cooler Racer
I don't have pics, but. The way I found it was lay on your back pass. side of engine. I reached right above the starter and felt it on the side of the block. If no cord is pesent, you'll feel what seems to be a threaded pipe about 1inch in diameter and it will have two metals prongs in it. If you can twist your head up in there, it is visible also.
So where do you leave the cord? I dont wnat to crawl under the truck everytime?
Have the cord come out in the space where your front passanger tow hook is.
You have to buy a cord from ford or international that plugs into that port on the block. From the block the cord will run up to behind the front bumper near the fog lights usually. That is where it terminates as far as where it should be from the factory, you then plug your house extension cord into the new cord hanging out of the front of your truck.
Mine came with a cord, they tucked it up inside the front bumper on the passenger side, need to fish around to find it the first time...
<--Pro Cooler Racer
I just got my first cord from eBay...my second came with my weather tight chrome plug that is mounted in the front bumper.
First time, I just zip-tied the plug end to the front tow hook.
Thanks for all the information, I will look again.
I think the years 04 and earlier the heater and cord came standard, but in 05 the cord became an option.
Moon
1 - 10 of 10 Posts
