1 - 20 of 26 Posts
at 182,000 miles, my 6.0l has bit the dust.
how hard would it be to bolt in a 7.3, will it bolt up to a torqshift tranny? I sure I will need all wireing and computers as well, but is there anything else that is not obvious that I will need.
Lt. Negativity
No it wont bolt up. What exactly happen to it.
12 Valve !
Don't mind me
Curious as to what happened to it also.
it started blowing oil out of the water resivour.
why wouldnt it bolt up? my dad has a 03 with a 7.3..... what are the diffrences?
Oil cooler went:doh:
6.0 has different engine mts, Completely different trans, PCM,TCM Driveshafts. Just to start
Does the 6.0 still run?
oh noes! the cummins crowd. whatever floats your boat man. make a conversion kit for the 7.3 and sell the plans :thumb:
6.0
if your truck still runs its probably the oil cooler. I had this happen on mine and it really makes you think your truck has died. Mine had 198000 when this happend.
if the truck still runs then its probably the oil cooler. I had this happen to mine at 198000 miles . I really make you think your truck has died
Discussion Starter #13
It still runs. If I change to oil cooler how do I get the oil ot of the rad and everthin else?
Don't mind me
Flush the system. I am sure that it is more involved than that but it gives you a starting point. Maybe one of the techs will chime in.
Yup flush system replace oil cooler and drive truck:thumb:
Discussion Starter #16
I will have to fix it before I flush it or it will just dump more oil in it correct.... can you use any kind of detergent or anything like that?
Also is there anyway to tell for sure its the cooler and not the head gaskets? I would hate to spend the money on a new oil cooler and still have to replace the motor.
Shoot Scuffy828 a PM. But im about 98% sure its the oil cooler
Discussion Starter #18
I pulled the dipstick after my last post and there doesnt appear to be any water in the motor but its hard to tell because there wasent much oil on the stick either. I would think if there isnt any water in the motor then it isnt head gaskets.
Sounds like the 6.0 will live agian!!!!!!!!! now I just need to fine a oil cooler for cheap because I'm currently laid off.
Haven't people totally removed the oil cooler?
Discussion Starter #20
I dont think thats possible, there are people that have completely removed the egr cooler. I made a write up on how to do that a year ago or so.
1 - 20 of 26 Posts
