1 - 8 of 8 Posts
I'm going for about 500hp and I would like to know if this setup will hold up under that power. Suncoast xtreme duty master rebuild kit, bts valve body and roadrunner triple clutch torque converter. Thanks for any help!
no it won't.
BTS or JW are the only ones that will realistically hold up to that kind of power.
Sent from AutoGuide.com App
Thanks, guess ill be returning the rebuild kit
Delivers Pizzas For Fun!
I think john wood will sell u a kit that uses all the stuff he does and it comes with a modded valve body and plate
What do you think those brands use for frictions and steels? Likely Alto and Kolene with added discs. It's not magic. I'd run it with 500hp...
Edit: If you want to build it yourself, call Racer X, tell him what you want, and he'll sell you everything you'll need to run the power you want.
1 - 8 of 8 Posts
