my 02 superduty with the 7.3 will not go into four will drive checked all the fuse and relays thay are working so i replaced the computer mod behind the glove box that worked now the 4x4 lights will not turn off when u put it in 2x2 and yes i can feel it jumping out of 4x4 :dunno:
First, learn how to make a sentence. Second, pull the vacuum hoses from the hubs on the front wheels. Plug one, put a vacuum gauge to the other. Turn the truck on, then the 4x4 on. See if you get and hold a vacuum. If you do, the problem is in a hub. Remove the locking hubs and replace the seals (both the black and yellow ones). Then test them to see if they hold vacuum.
First don’t be an ***, seconded I checked all that its fine it was a bad rebuild on the electronic shift motor and the 4x4 mod what happen was the shift motor shorted and fried the 4x4 mod and yes it works like a charm now.
There are those little symbols "." "," they help a bunch with understanding what
you are trying to say. Remember you are asking for help, make it easy for folks
to help you.
Good luck getting anyone to reply with your attitude.
