1 - 20 of 21 Posts
· Registered
I thought my truck had the offroad package but now I'm not sure. I only got one tire spinning. But I believe the offroad package includes the limited slip. Anybody know if there is any way to tell if a truck has the offroad package? Anything to look for?
· Registered
Look at the code on the rear axle tag. If it has an "L" in it the you have limited slip.
· assistant director
or you can look at the axle code on the door jamb sticker and then look in your owners manual to find out what it is
· Registered
or the sticker that was on the window when new, if you still have it.
· Registered
My 6.0 has limited slip but it usually one-wheel peels. My 7.3 limited slip works better.
I read a post on here somewhere, a guy said they (Ford) started taking one of the clutch discs out of the LS because people were complaining about on road manners.
· Registered
Discussion Starter · #11 ·
I wish they would put it back in then. One tire spinning is useless to me.
· Registered
Thanks for all your help guys. Now... any ideas? Should I take it back to ford or what? I have also heard that there is an additive to put in the axles with limited slips/lockers? Should I just change the fluid and add the additive?
It couldn't hurt but I'm not sure how much good it will do.
How many miles on the truck?
· Registered
The fluids in there should still be fine. Maybe one of the tech will chime in about tightening it up.
1 - 20 of 21 Posts
