21 - 25 of 25 Posts
california deplorable
i cant find any pics and have to run to town right now i will try again when i get back
i have the worlds worst internet. :doh:
all ican find is the piin point test which may or maynot help yohu at this point but...
PINPOINT TEST E: NO COMMUNICATION WITH THE MODULE — GENERIC ELECTRONIC MODULE
² E1: CHECK FUSE JUNCTION PANEL FUSE 15 (5A)
² E2: CHECK FOR VOLTAGE AT FUSE/JUNCTION PANEL FUSE 15 (5A)
² E3: CHECK FUSE JUNCTION PANEL FOR SHORT TO GROUND
² E4: CHECK CIRCUIT 676 (PK/O) FOR OPEN
² E5: CHECK THE POWER DISTRIBUTION BOX FUSE 22 (50A)
² E6: CHECK CIRCUIT 1052 (T/BK) FOR OPEN
² E7: CHECK CIRCUIT 70 (LB/W) FOR OPEN
² E8: CHECK CIRCUIT 676 (PK/O) FOR SHORT TO POWER
² E9: CHECK CIRCUIT 465 (W/LB)
² E10: CHECK CIRCUIT 465 (W/LB) FOR SHORT TO POWER
² E11: CHECK CIRCUIT 682 (DB) FOR SHORT TO POWER
² E12: CHECK CIRCUIT 682 (DB) FOR SHORT TO POWER (MULTI-FUNCTION SWITCH DISCONNECTED)
² E13: CHECK CIRCUIT 684 (PK/Y) FOR SHORT TO POWER
² E14: CHECK CIRCUIT 684 (PK/Y) FOR SHORT TO POWER (MULTI-FUNCTION SWITCH DISCONNECTED)
² E15: CHECK CIRCUIT 519 (LG/BK) FOR SHORT TO POWER
² E16: CHECK THE HORN RELAY
² E17: CHECK CIRCUIT 810 (R/LG) FOR SHORT TO GROUND
² E18: CHECK CIRCUIT 22 (LB/BK) FOR SHORT TO GROUND
Reactions: heisman01
Discussion Starter #22
This is for a 2011?
it was supposed to be but i cant verify
Discussion Starter #24
Well I finally had time to checking this out. I don’t think it’s for an 11. A lot of the fusing didn’t like up. If anyone is a service tech for these trucks specifically please help.
Every fuse has power that deals with 4x4
motor power lines show voltage
Can turn the transfer case by hand when truck is lifted
Front hubs lock so not a seal issue/vacuum issue
Can turn 4x4 motor with a 12v battery off of and on the truck
Control plug has 2v to 2 of the 6 ports, I can’t find any details on line as to what it should be?
Discussion Starter #25
Still haven’t found the issue if anyone’s wondering or having similar problems.
21 - 25 of 25 Posts
