I went fishing this weekend and ended up getting stuck. When i switch it to 4hi the 4x4 indicator and the tcs light started flashing. I then tried 4lo and got the same result. I went through the (put it in netural and step on the brake then put it in lo) process and never could get it to engage. My hubs are locked in as well... and ideas??
I can't be much help but maybe the vac. Lines to the hubs cracked or fell off. I wish they were all thill manual 4x4 personally more electronics = more problems
2004 f250, dual 5" chrome stacks 285/75/16 at 10 ply, Vivian's looney (awesome) duplicolor spray bed liner on my rockers and fender lip 10" high
My vacuum pump doest come on when i turn the key on and i have checkd all the fuses and relays for the 4WD system and found nothing wrong with them.. i also notice that when i turn the switch on in the cab the switch motor on the transfer case doen nothing. so im guessing its bad?? what else can i check?
