Just wondering if anyone has done this? is it possible? what needs to be done? If anyone has then pics would also be great!
different wheel offsets will usually correct your problem.how do you get tires that big to barely rub the leaves??? my 36s love to rub. I could barely turn before, now even most 4x4 U-turns are out of the question
or spacersdifferent wheel offsets will usually correct your problem.
Thats exactly how i want my truck to sit, thanks for the help and pics.8in fab tech 24x10s and 40x14.50s.. my truck.. barley any trimming at all... it still scrubs if you try and flex it out, but i dont do any off roading with my truck so i pretty much never scrub..
dont *****e out on spacers either, cheap spacers will result in failure.I think I would stop you just so I could look at it up close, thats a nice truck. the only thing I get asked about is my lawnmower.
where would I find spacers?
all I had to cut for my tires was the front bumper and I had to take off the running boards. much bigger and I would have to cut the cab corners
