1 - 5 of 5 Posts
im looking to make around 400hp out of my 95.
its in the process of new body but when im done with that i plan on building up the motor.
so at first i am just gonna go with gauges intake exhuast and tony wildman chip.
then i want the build up the trans, put in headstuds, so it can hold the power?
then hybrid injectors, electric fuel system. now tell me what else i need i know theres more i just cant think of it.
You will also need a new turbo. Intercooler wouldnt be a bad addition either
:doh: i duno how i forgot to say those to but what kind do you all recomend on the parts
Hybrids, fuel system, turbo (at least and H2E), head studs, BTS transmission, and you should be about there. That's after the basics of gauges, intake, exhaust, and chip.
With a 95 15* HPOP I'd look at upgrading to a 17*SD HPOP You can easyly get 400HP with 2's also.
Turbo..Beans D66 or a H2e
Intake and exhaust..Tymar..best for the $$
BTS or John Wood trans...only choices IMO
Don't forget a RS kit and SD springs when you install the D60
Cary
1 - 5 of 5 Posts
