Ok, here is my problem. I have a 97 F350 crew cab with a front bench seat. Igot a set of 40/20/40 seats out of a 96 F150 extended cab. Unfortunately none of the mounting holes match and there are no holes for the center console. Does anyone know if the seats will fit, and if they will, what's the best way to mount the new seats. Thanks for any help.
Super cabs floors are different than CC or Reg. cabs. You can swap the rear seat of the CC to the front, or use a seat from a reg. cab, but the mounting is different on a SC.
I just got a 40/20/40 seat out of a crew cab off ebay. I pulled the bench seat out of the back. Moved my old front seat to the back and installed the new seat in the front so I have buckets front and back. If you find a seat from a crew cab or regular cab it's a direct bolt in, but the super cab seat won't work.
