I put my 2000 F-350 in 4 wheel drive. When I switch it back to 2 wheel drive with the switch on the dash, nothing happens. I have to pull the drive motor off the transfer case then use a wrench to get it back into 2 wheel drive. I have changed the dash switch, nothing changed. I bench tested the motor off the transfer case and it moves in both directions. I have also changed the relays under the hood, no change.
Anyone have any idea's ?
Do you have manual or auto hubs on the front? Is it possible the T-Case is disengaging but the axle isn't making it feel like its in 4x4?
I have to stock auto hubs. The transfer case is still in 4 wheel drive. I can grab the front driveline and it wont turn until I remove the motor and manually get it back into 2 wheel drive.
