I've been looking at the skyjacker 4 inch lift leaf springs for the front of my truck. But I'm not sure of what all else I'll need to change out as well. I'm wanting to run 315/75/16. Thanks for any help. My truck is a 2004 f250 crew cab.
You will need a pitman arm, a track bar drop down bracket, longer sway bar end links, and longer shocks. My stock brake lines still work... on the street, but I haven't had it off road yet. (well, not much) I still have to re-gear after the lift. I'll be going with longer braided brake lines.
Dang I was hoping it was gonna be fewer parts then that. Thanks for the info.
