Ok, so I'm finally going to get my gears just wanted everyones opinions on which ones to get? Currently I'm running 3:73's on 20's and from what Randy's Ring and Pinion website here is the rpm ranges for all:
When I was running stock (3:73's and 31 in tires): RPM at 55: 2283
With 4:30's: 2205
With 4:56's: 2339
What I'm at with my 37's and 3:73's: 1913 (all bad!)
As you can see my rpm range right now is horrible and I need to get this done....
The 4:30's would put me closest back to stock, but I pull a 30 foot fifth wheel so I'm thinking about just going with the 4:56's? Not to mention the 4:56's are about $100 cheaper per axle.
Would running the 4:56's be bad on the highway? Anyone currently running 4:56's on 37's and if so how do you like them? Thanks all...
With 4:30's: 2205
With 4:56's: 2339
