1 - 5 of 5 Posts
hey , my buddy is getting new tires so hes giving me his old ones theyre like new bfg mud terrains, there 33x9.5x15 if i get enough backspacing in the rims will they look normal? , i think theyre to skinny idk though, if i can find some old 15" rims for cheap, will they fit around my rotors alright? thanks
I dont think so, I know the f-150s need at least 16 inch wheels. They wont clear the calipers. I think the SD's are the same way.
Even if you could get them to fit I’d bet they are not rated for enough weight to be safe on your superduty. Be careful when putting larger tires on a real truck, make sure the weight rating and max air pressure is high enough.
PMR = JUNK
Even if they fit i wouldn't use them. Tires that skinny would look kinda :tard::tard::tard:.
i would be worried about the wieght as stated above
1 - 5 of 5 Posts
