1 - 11 of 11 Posts
have
DIY intake
mbrp 4'' turbo back
thinking of getting
38R turbo
injectors but do not know what size
dp tuner
BD-Power intercooler
questions i have am i going to need valve springs,regulated return or studs
to make this work
To get 300hp + total or a gain of 300 over what you have? If your truck is healthy, an intake, exhaust and good tunes should put you over 300hp. If your truck s not healthy, I'd suggest fixing it and maybe use upgraded parts first.
now to get 300 over stock, your gonna need a lot more than your list.
well the truck has 180,000 on it runs pretty damn good
is that 300hp to the wheels?
because i want to put 300 + to the wheels
On stock tunes, with just a Ford AIS intake and 4" MBRP turbo back, my truck with 190,000 put down 242/504 hp/tq. With a good tune, similar trucks are putting 325-350hp
well 325 to 375 is right around where i want to be so maybe with some good tunes and decent injectors i can get up there but with just intake 4''mbrp and some tunes is a good place to start
you may not even need to upgrade injectors. you should be able to get an extra 100 horse out of your stockers
Discussion Starter · #7 ·
well thats good to know cuz the injectors are brand new have less then 500miles on them
intake, exhaust, chip. Done.
And drop the idea of head studs and an intercooler..... the stocker is fine.
You may want to invest in a fuel crossover to keep those rear injectors healthy. Especially if your going to get custom tunes.
I still have stock injectors with the 38r, put out between 350-375hp at the rear wheels. Thats with aFe stage 2, 4" and meth-injection. Got the bully dog gt too...for all the haters out there. Very dependable daily driver...gets beat on.
Don't worry about the HP#'s so much.
Worry more about your torque #'s.
In the end, torque is going to give you the seat of the pants feeling and better performance when using the truck for towing/hauling. Just my :twocents:
1 - 11 of 11 Posts
